Article ID : 00167918 / Last Modified : 18/02/2020
TV leans back a little on the table-top stand
    Your BRAVIA TV is designed to be slanted slightly backwards in consideration of setting it on a low board.
    If the TV is set at a low position, your eyes will lower a bit when you sit on a sofa. According to ergonomics, your eyes are 15 degrees lower while sitting than when you are in a usual relaxed state. You will be able to enjoy watching TV programmes more comfortably by turning the TV screen a little upward.
