Article ID : 00167738 / Last Modified : 06/01/2017
How to avoid outputting the computer sound from the TA-ZH1ES
    Open Control Panel then select Sound and the Playback tab.
    Then select Speakers etc. as the Default Device.
    By selecting this setting, the TA-ZH1ES only outputs sound from software (Hi-Res Audio Player, etc.) which allows ASIO driver output.
    Computer sound will be output from the speakers on the computer.
