What headphones does the device support?
Can I connect to more than one terminal?
The headphones supporting the device are as follows.
Balanced standard (4.4mm in diameter), 3-pole mini (balanced connection, 3.5 mm in diameter) x 2, XLR4 (balanced, 4 pins), Standard (6.3 mm in diameter), Stereo mini (3.5 mm in diameter)
For US Region:The impedance of headphones corresponds to 12-600 ohm.
For Other Region:The impedance of headphones corresponds to 8-600 ohm.
[A] |
XLR4 headphone jack | balanced 4 pins | |
[B] | Stereo mini headphone jack | 3.5 mm in diameter | |
[C] | Standard headphone jack | 6.3 mm in diameter | |
[D] | Balanced standard headphone jack | 4.4 mm in diameter | |
[E] | 3-pole mini headphone jack | 3.5 mm in diameter | |
NOTE:
- Sound cannot come out simultaneously from two or more jacks. The sound comes out only from the headphone terminal selected in OUTPUT or PRE OUT terminal.
- Although headphones with the noise canceling function are available for use, noise may be heard when you are playing the DSD signal.
