Article ID : 00171784 / Last Modified : 07/08/2020Print
How to change the Screen reader language to a different language
    The Screen reader language can be changed only when the TV is connected to the Internet.
    For details on how to change the language, try the following steps.
    1. Press the HOME button on the remote control.
    2. Select cog wheel icon Settings.
    3. Select Accessibility in the System Preferences category.
    4. Select Text to speech.
    5. Select Engine configuration. (For Android™ 7.0 or later)
    6. Select Language, then select the desired language.
