How to set the volume level to one standard for all input sources and broadcasts
Sound adjustments
You can adjust the volume level of broadcasts and external inputs in the Sound adjustments options:
- Advanced auto volume: adjusts all volume levels automatically
- Volume offset: adjusts volume levels individually
Adjusting the volume level automatically
Advanced auto volume improves volume level differences when the volume level difference is large in the following cases:
- commercials and actual broadcast
- each broadcasting station
- broadcast (Digital/Analog) *Available countries/regions only
- each external input
This setting automatically adjusts the volume to a fixed level that matches to the volume changes of the broadcast and input signal. It's an effective setting when for instance, the volume of commercials feels louder than the volume of the program.
- Switch to the broadcast (or input) you want to adjust the volume of.
- Press the Home button on the remote.
- Select Settings.
- Select Sound.
- Select Sound adjustments.
- Select Advanced settings.
- Select Common and press the → button to move the cursor to the option menu on the right.
- Press the ENTER button and set the Advanced auto volume to Auto.
- Press the BACK button on the remote to return to the home menu.
Adjusting the volume level individually
This setting is related to the speaker volume of the BRAVIA TV. Therefore the volume of headphones and external outputs cannot be adjusted. Also, if the audio level is low even though the surround function is enabled, disable the surround function.- Switch to the broadcast (or input) you want to adjust the volume of.
- Press the HOME button on the remote.
- Select the Settings.
- Select Sound.
- Select Input related and press the → button to move the cursor to the option menu on the right.
- Select Volume offset.
- Adjust the volume with the ←/→ button on the remote, then press the ENTER button.
Settings for volume adjustments is now complete.
