Article ID : 00178643 / Last Modified : 18/12/2018
How can I reconnect my Bluetooth device?
How do I disconnect a Bluetooth device that is kept as Registered devices?
If you have connected the Bluetooth device once before, you can disconnect it with the registered information intact. Therefore, the next time you want to connect, you can do so without deleting paired registration or registering your device.
Check the following operation.
Disconnecting the Bluetooth device
  2. Select Settings.
  3. Select Bluetooth settings.
  4. Select Registered devices.
  5. Select Bluetooth device name.
  6. Select Disconnect.
Reconnecting the Bluetooth device
  2. Select Settings.
  6. Select Connect.
