Article ID : 00179393 / Last Modified : 03/02/2022Print
Points to be checked when using Chromecast built-in (Google Cast) with the Sound Bar or AV Receiver.
    Before start using Chromecast built-in (Google Cast) in your Sound Bar or AC Receiver please check to see if Chromecast built-in (Google Cast) is version 1.21 or later for use in Sound Bar or AV Receiver.
    Check the version using the following process.
    1. On the Sound Bar or AV Receiver remote control, press the HOME button.
    2. Select Setup.
    3. Select System Settings.
    4. Select System Information.
    5. Check the Chromecast built-in (Google Cast) version.
      NOTE: If the version is old, please update the software of the Sound Bar/AV Receiver. For more details about the software update, please refer to the Operating Instructions/Help Guide.
