How do I change back the TV app to the default app?
Perform one of the following procedures so that the default app launches.
Uninstall the added app.
- Press the Home button on the remote control.
- Select Settings.
- Select Apps in the TV category.
- Select the added app from Downloaded apps.
- Select Uninstall.
- Select OK.
Change the settings so that the default app launches.
- Select Settings.
- Select Clear defaults.
- Select OK.
- Watch TV after performing the settings above. When a dialog is displayed, select OnAir, and then select Always.
