Article ID : 00191179 / Last Modified : 20/12/2017
Post-Sports Maintenance of MDR-XB50BS.
    Check the following for how to maintain MDR-XB50BS after sports-related activities.
    Wipe the headphone and micro USB terminal with a soft, dry cloth. If there is moisture on the interior, it may cause malfunction.
    Tips
    • Completely close the micro USB terminal cap before use so that the interior does not accumulate moisture.
    • If the device or USB terminal comes in contact with moisture from sweat or another source during running or another activity, completely remove any moisture.
    • When the device or charging cable is wet, do not insert the micro USB plug to charge. Start charging only after completely drying the device.
