Article ID : 00197331 / Last Modified : 26/04/2022Print
Troubleshooting (Android TV): How to check if the cause of the problem is in a downloaded application and how to resolve it
    Check the following.
    If the BRAVIA TV does not work correctly, there is a possibility that downloaded application is affecting the operation. Start the TV in safe mode and check if the symptom occurs again while the downloaded application is disabled.
    For details on safe mode and how to operate the Safe mode, refer the following.
    How to turn on/off the Safe mode?
    NOTE: Related Troubleshooting: Troubleshooting (Android TV): What are the benefits of restarting the TV and software updates? / Issues with the sound and screen
    1. Please update the application to latest version from Google Play Store.
    2. Perform Clear data by following the procedure below.
      2. Select Settings.
      3. Select Apps in the TV category.
      4. Set Running app or system app.
      5. Choose the application with problems.
      6. Select Clear data then OK.
    3. Inquire to the web page or the e-mail address listed in FULL DESCRIPTION of each application.
      2. Select Google Play Store.
      3. Select My Apps.
      4. Choose the application, then FULL DESCRIPTION.
    4. Consider uninstalling the application.
