How to pair a remote control with Sony's Android TV via Bluetooth
The Bluetooth voice remote supplied with your TV is initially paired at our factory. However, when your voice remote is exchanged (at service) or if it stops working,
you may have to re-pair your voice remote with the TV.
- Press the [HOME] button, select [Settings]
- Select [Voice Remote Control] and press the [Activate button]
- Prepare Voice Remote Control
- Press and hold down VOL- button
- Press and hold the [Activate button]
for 3 seconds while holding down VOL- button
NOTE: For Android Oreo (OSV-O), the settings icon is located in the top right-hand corner.
Visuals voice remote pairing
