Article ID : 00244850 / Last Modified : 17/04/2020
What accessories or lenses are compatible with my camera or camcorder?
    You can find out which accessories or lenses are compatible with your camera or camcorder on the Product Page.
    1. Getting to your Product Page
    1. Make sure you know your model name. If you are unsure, this page can help you find it:
    2. Type in your model name in the search bar on the Support website.
      IMPORTANT: Make sure you type your model name correctly (including the hyphen (-) if applicable). The predictive search feature will help you make sure you’re typing the model correctly.
    3. Go to your Product Page by clicking on your product name in the auto-suggest feature or in the search results.
    2. Make sure the All tab is selected.
    3. When you scroll down you will see Accessory Compatibility and/or Lens Compatibility (or both).
    4. Click each link in turn and check the Compatibility Information.
