Article ID : 00227235 / Last Modified : 25/05/2022Print
The wireless speaker cannot be charged using a USB AC adaptor.
The CHARGE indicator on the speaker does not light up.
    Check the following if the CHARGE indicator doesn't light up in orange on the SRS-XB501G Portable Bluetooth® Speaker:
    SRSXB501G charge light location
    • Make sure the USB cable is securely connected to your speaker and USB AC adaptor.
    • Make sure the USB AC adaptor is securely connected to a working wall outlet.
    • Charging with a USB AC adaptor won't be possible if the internal battery of your speaker is consumed or isn't used for a long time. If this happens, use the supplied AC adaptor.
    • Use a USB AC adaptor with an output current of 3.0 A or more and a USB Type-C™ cable.
      • You can use the USB AC adaptor for an iPhone® cellphone or iPad® tablet, but charging time may take much longer.
