Article ID : 00225588 / Last Modified : 27/06/2019Print
Unable to connect Android phone to UDA-1 Stereo amplifier
    Different USB port specifications
    The UDA-1 Stereo Amplifier is equipped with two USB-ports which enable you to connect your smartphone. However, because the front and rear USB terminals on the UDA-1 have different technical specifications, the front USB port does not support Android 9.
    Connecting to the rear USB port that supports Android 9
    Since only the rear USB port supports Android 9, you will need to connect your smartphone with the supplied USB-B to USB-A cable in combination with an adaptor “USB-A to USB port” on your smartphone.
    Make sure to check which USB type your smartphone has before acquiring the right adaptor.
    Overview of USB types
    USB types
