I didn’t say "Ok Google" but Google Assistant came up
IMPORTANT: This article only applies to specific products and/or operating systems. Please check the Applicable Products and Categories section of this article.
If "Ok Google" comes from the TV, for example during a commercial, the TV's Built-in microphone might react to it.
Press the BACK button on the remote control to cancel the Google Assistant ready status.
Check the TV position setting.
- Press the HOME button on the TV remote control.
- Select
Settings.
- Select Sound or select Display & Sound and then select Sound.
- Select TV position.
- Select Table-Top stand or Wall Mount.
NOTE: When the Accessibility (Screen Reader or Talkback) setting is on, Google Assistant may also react to the TV reading the words "Ok Google".
