Article ID : 00230235 / Last Modified : 16/07/2019
Apps added to the home screen won't start when tapped
The apps added to the home screen through Settings Add Apps may not start when tapped after you update the App Remote for Android to Version 2.2.1. Follow these steps to access the apps:
  1. On your smartphone, open the App Remote app.
  2. Select Settings.
  3. Select App Control by Voice.
  4. Register the apps that won't start through the following options:
    • Navigation App Menu
    • Phonebook App Menu
    • Audio App Menu
    • Video App Menu
