Article ID : 00242918 / Last Modified : 18/10/2022Print
How can I determine which Bluetooth codec is being used by my headphones?
    You can check which codec is being used by the smartphone using the Sony | Headphones Connect app:
    • Subband Codec (SBC) or
    • Advanced Audio Coding (AAC)
    The codec used to make a Bluetooth® connection depends on the type of connected device, its Operating System, software version, and device settings.
    Headphones connect screenshot with shows codec info
