Article ID : 00247882 / Last Modified : 26/06/2020
New Android 10 software available for Xperia 1
    Information / Solution
    Note! Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when the update will be available for your device.
    Software build number
    • Xperia 1: 55.1.A.8.1
    This system software update features
    • Android security patch level: 1 May 2020
    Updating your device
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
    When a software update is available, appears in the status bar.
    To download and install a system update from the Notification panel
    1. If you are using a device with multiple users, make sure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down and select the wanted system update, tap the item and then tap UPDATE.
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
    Why hasn't my device received an update yet?
    • Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models.
