Article ID : 00242955 / Last Modified : 20/01/2026Print
I can't use Side sense when the cover is attached
    Follow the steps below to enable the "Operate on inner edge of screen" function of your mobile device to use Side sense with the cover attached.
    1. Find and tap Settings → Display → Advanced → Side sense → Configure touch position.
    2. Select Manual and tap the switch beside "Operate on inner edge of screen" to enable the function.
