Article ID : 00243022 / Last Modified : 26/06/2020
Stereo Bluetooth Headset SBH52 Application
    To download applications directly from this website, you need to enable downloads from sources other than Google Play on your device.
    Note: Installing applications from unknown or unreliable sources can damage your device. Download applications only from reliable sources.
    Click the Download button if you wish to proceed with download and installation.
    Terms of use for Sony Mobile applications
    We recommend that you download and install the app directly on your mobile device.
    Android 8 and higher
    Android 7 and lower
    We recommend that you disable the installation of applications from unknown sources after installing Sony Mobile applications from this website.
    Check APK signature
