Article ID : 00242293 / Last Modified : 13/11/2020
SmartWatch 2 SW2 Application
    To download applications directly from this website, you need to enable downloads from sources other than Google Play on your device.
    Note! Installing applications from unknown or unreliable sources can damage your device. Download applications only from reliable sources.
    Click the Download button if you wish to proceed with download and installation.
    Terms of use for Sony Mobile applications
    We recommend that you download and install the app directly on your mobile device.
    How to install an APK file
    You can install APK files on your smartphone directly from your browser.
    1. Use the download link below to download the Smartwatch SW2 application directly on your phone.
    2. Once it's downloaded, open Downloads, tap on the APK file.
    3. Tap Yes when prompted. The app will begin installing on your device
    To enable or disable download of applications from other sources
     Android 8 and higher
     Android 7 and lower
    We recommend that you disable the installation of applications from unknown sources after installing Sony Mobile applications from this website.
     Check APK signature
