Article ID : 00247774 / Last Modified : 12/11/2021
New Android 9 software available for Xperia L4
    Note! Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date when the update will be available for your device.
    Software build number
    • Xperia L4: 57.0.A.2.295
    This system software update features
    • Android security patch level: 5 September 2021
    Updating your device
    Tip: To check your device's current software version, find and tap Settings → System → About phone → Build number.
    When a software update is available, the refresh icon appears in the status bar.
    To download and install a system update from the Notification panel
    1.     If you are using a device with multiple users, make sure you are logged in as the owner.
    2.     Drag the status bar downwards to open the Notification panel.
    3.     Scroll down and select the wanted system update, tap the item and then tap UPDATE.
    4.     When the download is finished, open the Notification panel again. If it is closed, tap RESTART.
    Why hasn't my device received an update yet?
    • Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models.
