Article ID : 00250145 / Last Modified : 01/04/2021
How to wall mount your TV (XH80, XH90, XH92, XH95 series of 55, 65 inches)
    This page is a guide for using the compatible Wall Mount Unit (SU-WL450) to mount the XH80, XH90, XH92 and XH95 series (55 inch and 65 inch) on a wall.
    IMPORTANT:
    For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    1. Precautions
      • For more detailed information and precautions about wall mounting, see the Wall-Mount Bracket Operating Instructions and the Installation Information (Wall-Mount Bracket) on the product page of your TV.
      • The wall should be capable of supporting a weight of at least four times the TV weight. Regarding the TV weight, refer to Wall mounting compatible information.
        Sufficiently reinforce the wall to which the TV will be mounted if it is not strong enough.
      • Be sure to use the supplied screws and attachment parts properly. If you use substitute items, the TV may fall and cause bodily injury to someone or damage to the TV.
    2. Preparing the required parts and tools
      Confirm that you have all of the parts.
      • Accessories for the Wall Mount Unit (SU-WL450)
        Only the parts below will be used. The other parts will not be used, so store them with the Operating Instructions in a safe place.
        [A]Base [B]Pulley [C]PSW 6×20
        [E]Spacer(20) [F]Belt [I]Base Adaptor
        [J]PSW 4×10 [K]Spacer(60) [L]PSW 6×50
      • Accessories for the TV
        The Wall-Mount Attachment “VS” will be used.
        NOTE:
        The Wall-Mount Attachment “VS” is included with the TV. Please note that it is not included with the Wall Mount Unit.
      • Other things to prepare
        Prepare the types of tools and screws below based on the material of the wall to which the TV will be mounted.
        Electric drill Screwdrivers Pencil
        Level guide Four or more screws of 8mm diameter or equivalent One 5mm diameter screw or equivalent
    3. Mounting the Wall Mount Unit to a wall
      1. Deciding on the mount position of the TV
        1. Decide on the approximate “height” at which the TV will be mounted.
          Take into account the environment where you will watch TV (such as the sofa) when deciding the mount position such as “height”.
        2. Decide on the mount position of the TV.
          Check whether there is enough space (width, height, depth) on the wall to mount the TV.
          The clearance dimensions in the figure below are required to prevent heat from accumulating around the TV.
          NOTE:
          If the TV is mounted without surrounding clearance, the vents will get blocked and heat will accumulate inside, which may cause a fire or damage.
          Figure of dimensions for the space needed to mount the TV. The space needed around the TV is 300mm above, 100mm at each side, and 100mm below.
          Unit: millimeter
        3. Decide on the mount position of the base of the Wall Mount Unit.
          Decide on the center position [1] of the TV screen.
          The position at a length of c(figure below) above the center position is the position of the screw holes at which the base will be attached.
          The length from the screw positions to the bottom edge of the TV is length d.
          For the dimensions indicated by letters in the figure, refer to the table below. (The figure is from KD-65XH8096)
          The left figure is the dimensions of the back of the TV (a: TV width, b: TV height, c: length from the center of the screen to the position of the screw holes at which the base will be attached). The right figure is a side view of the TV. (d: length from the bottom edge of the TV to the screw hole positions)
          Unit: millimeter
          [1]Center position of the screen when the TV is attached
          Model (KD-/KE-) aTV width bTV height cLength from the center of the screen dLength from the bottom edge of the TV
          65XH95xx
          65X95xxH
          1,448mm 833mm 71mm 492mm
          55XH95xx
          55X95xxH
          1,229mm 710mm 133mm 492mm
          65XH92xx
          65XH90xx
          65X90xxH
          1,450mm 833mm 71mm 491mm
          55XH92xx
          55XH90xx
          55X90xxH
          1,231mm 710mm 133mm 491mm
          65XH80xx
          65X80xxH
          1,462mm 841mm 71mm 494mm
          55XH80xx
          55X80xxH
          1,243mm 718mm 133mm 494mm
      2. Choosing the wall mounting style.
        Choose between two installation methods: Standard, which creates space between the wall and the TV, or Slim, which brings the TV closer to the wall. With Slim mount, the TV feels integrated into the wall, allowing for a more streamlined appearance.
        The installation process differs depending on the mounting style.
        NOTE:
        If you choose the Slim mount, use of the inputs on the back may be limited.
        Standard mount Slim mount
        Figure of the side of the TV (e: Depth when wall mounted with standard mount) Figure of the side of the TV (f: Depth when wall mounted with slim mount)
        Unit: millimeter
        Model (KD-/KE-) eDepth when wall mounted (for standard mount) fDepth when wall mounted (for slim mount)
        65XH95xx
        65X95xxH
        134mm 92mm
        55XH95xx
        55X95xxH
        134mm 92mm
        65XH92xx
        65XH90xx
        65X90xxH
        134mm 92mm
        55XH92xx
        55XH90xx
        55X90xxH
        134mm 92mm
        65XH80xx
        65X80xxH
        135mm 93mm
        55XH80xx
        55X80xxH
        131mm 93mm
      3. Mounting the base to the wall
        1. For Standard mount, attach the base adapter to the base.
          Confirm the “b” positions in the figure below for the attachment positions.
          * For Slim mount, attaching the base adapter is not required.
          Image of hook location a, b, c, d on the base
          Image of the positions on the base where the base adapters will be attached (b: attachment positions of the base adapters)
          Use the screws (PSW 4×10) included with the Wall Mount Unit to attach the base adapter to the base.
          [A]
          Base
          [I]
          Base Adaptor
          [J]
          PSW 4×10
          Image of where A, I, and J will be attached
        2. Place the base on the wall and align it with the screw hole positions set in “1-3 Decide on the mount position of the base of the Wall Mount Unit.” above, use a level so that the base is horizontal, and mark the mount position (4 screw holes).
          For the screw hole positions, refer to the figure below.
          Image indicating the screw hole positions where the base will be mounted on the wall
          • Standard mount
            Image marking the four places (top and bottom at both ends) where the base will be mounted
          • Slim mount
        3. Make holes at the marked points.
        4. Use at least four screws with diameters equivalent to 8mm (prepared separately) to mount the base to the wall.
          Use a level to mount the base horizontally.
          • Standard mount
            * Attach the four screws to the screw holes of the base adapter along with the base.
            [A]
            Base
            [I]
            Base Adaptor
            Image of where A and I are attached for Standard mount
          • Slim mount
            * Attach the four screws to the screw holes of the base.
            [A]
            Base
            Image of where A is attached for Slim mount
    4. Attaching parts to the TV
      Make sure to attach the Table-Top Stand before proceeding and installing the TV to the wall by referring to the Setup Guide.
      1. Remove the screws on the back of the TV.
        Remove four screws from the back of the TV.
        * Store the removed screws with the Operating Instructions in a safe place.
        Image of where the screws on the back of the TV will be removed
      2. Attach the Wall-Mount Attachment (supplied with the TV) to the rear of the TV (to make it parallel with the wall).
        Image of where the Wall-Mount Attachment
        1. Attach the pulley and screws (+PSW 6×20). Tighten the screws firmly so that they are not loose.
        2. Attach the belt and spacer with screws (Standard mount: +PSW 6×50, Slim mount: +PSW 6×20).
          • Standard mount
            [B]
            Pulley
            [C]
            Screws (+PSW 6×20)
            [L]
            Screws (+PSW 6×50)
            [K]
            Spacer (60mm)
            [F]
            Belt
            Image of where B and C, and then F, K, and L, are attached for Standard mount
          • Slim mount
            [B]
            Pulley
            [E]
            Spacer (20mm)
            [C]
            Screws (+PSW 6×20)
            [F]
            Belt
            Image of where B and C, and then F, E, are attached for Slim mount
      3. Connect the necessary cables to the TV.
        Connect the power cord, antenna cable, and HDMI cables before mounting the TV on the wall. Once you mount the TV on the wall, you will not be able to connect the cables. Make sure to connect them before mounting the TV on the wall.
        NOTE:
      4. Detach the Table-Top Stand from the TV.
        Remove one side of the Table-Top Stand at a time. Firmly hold the Table-Top Stand securely with both hands while the other people lift up the TV.
        Repeat the previous step and remove the other side of the Table-Top Stand.
        The figure is from KD-65X9500H.
        Image of detaching the Table-Top Stand from the TV
        NOTES:
        • Three or more people are required to detach the Table-Top Stand.
        • Be careful not to use excessive force while detaching the Table-Top Stand from the TV as it may cause the TV set to fall resulting in personal injury or physical damage to the TV.
        • Take care when handling the Table-Top Stand to prevent damage to the TV.
        • Be careful when lifting the TV as the Table-Top Stand is detached, the Table-Top Stand may topple over and cause personal injury.
        • Take care when removing the Table-Top Stand from the TV to prevent it from falling over and damaging the surface that the TV is sitting on.
    5. Attaching the TV to the Unit
      NOTE:
      Make sure at least two people hold the TV. When carrying the TV, hold the side and bottom of the bezel. Take care not to grab the panel surface with your hands, or press the panel surface firmly.
      Image of carrying the panel. if you carry by the panel surface, the screen may crack
      1. Attach the TV to the base adapter (Standard mount) or the base (Slim mount).
        1. Securely attach the pulley on the back of the TV while aligning it with the holes of the base adapter or base.
          • Standard mount
            [B]
            Pulley
            [K]
            Spacer (60mm)
            [F]
            Belt
            Image of attaching the TV while aligning it with the holes of the base adapter for Standard mount
          • Slim mount
            [B]
            Pulley
            [E]
            Spacer (20mm)
            [F]
            Belt
            Image of attaching the TV while aligning it with the holes of the base for Slim mount
        2. Confirm that the pulley properly reaches the ends of the grooves on the base adapter or base.
      2. Prevent the bottom of the TV from wobbling.
        Attach the belt to the wall so that it is not loose, and secure it in place using a screw with a diameter equivalent to 5mm (prepared separately).
        * Gently pull the bottom of the display forward and confirm that the lower side does not rise forward.
        If it does, secure it in place again while making sure the belt is not loose.
        [F]
        Belt
        Figure of the side of the TV (F: secure belt in place with a screw)
        [F]
        Belt
        If the TV is confirmed to be firmly secured on the wall, mounting is complete.
        Enjoy your BRAVIA TV with a wall mounting style that blends in beautifully with your wall.
