Troubleshoot Truly Wireless headphones Bluetooth pairing issues
This page introduces how to troubleshoot for Truly Wireless headphones Bluetooth pairing issues.
Check the state of the indicator when you turn on the headset after initializing it.
The location and color of the power indicator differ depending on the product.
When you initialize the headset, it returns to factory settings and all Bluetooth pairing information is deleted.NOTE for WF-SP900:
All of the data (music files, pre-installed data, etc.) saved to the main memory of the player will be erased. Before initializing, backup any important data.Refer to the following to initialize the headset.
WF-1000XM3
Initialize the headset to restore the factory settings. Visit the Help Guide or view the video on how to initialize the headphones.
WF-H800
- Initialize the headset to restore the factory settings. See the Initializing the headset section in the How to reset or initialize the headset article or view the video on how to reset the headphones.
WF-SP800N
WF-SP900
WF-XB700
- Initialize the headset to restore factory settings. See the Initializing the headset section in the How to reset or initialize the headset article.
- Blue and red indicators flash alternately / Blue indicator flashes twice at a time
- The headset is initialized and is in Bluetooth pairing mode.
Go to step 2. - The indicator flashes twice and then turns off
- The headset turned on without being initialized.
Initialize the headset again. - Does not flash
- It may not be possible to charge correctly.
Refer to the following article:
Troubleshoot why the Truly Wireless headphones are not charging
Can you complete Bluetooth pairing after performing the following operations in order?
Delete the Bluetooth device information of your playback device.
For details, refer to the following article:
How to delete the Bluetooth device information of your playback device -
Perform pairing again.
For details, refer to the following article:- Pairing and connecting with an Android smartphone
- Pairing and connecting with an iPhone
- One-touch connection (NFC) with a smartphone
- For other devices, refer to the following article: How to pair Bluetooth headphones with a Bluetooth source device.
- One-touch connection (NFC) with an Android smartphone
WF-1000X
WF-1000XM3
WF-H800
WF-SP700N
WF-SP800N
WF-SP900
WF-XB700
- Pairing was successful
- There seems to have been an issue connecting with the playback device, such as Bluetooth pairing being disconnected.
- Pairing not successful
- Go to step 3.
Can you perform Bluetooth pairing normally with other devices?
If you have another smartphone, Walkman, or other device, try pairing it to the headset via the Bluetooth function.- Pairing was successful
- The playback device that was initially connected may be malfunctioning. Consider inspecting the playback device.
- The headphones may be malfunctioning. The Service may be required.
