Can I connect wireless speakers (SRS-X**) with different wireless speaker models?
You can connect a wireless speaker (the models with prefix SRS-XB**) to other speakers with the same wireless function supported.
For more information on the Wireless Party Chain function, check the online help-guide, available on the product page of your device.
Devices compatible with the Wireless Party Chain function:
- SRS-XB20
- SRS-XB21
- SRS-XB22
- SRS-XB30
- SRS-XB31
- SRS-XB32
- SRS-XB40
- SRS-XB41
- GTK-XB60
- GTK-XB72
- GTK-XB90
Devices compatible with the Party Connect function:
- SRS-XB23
- SRS-XB33
- SRS-XB43
- SRS-XG500
- SRS-XP500
- SRS-XP700
NOTE: You cannot connect Wireless Party Chain supported wireless speaker models in combination with Party Connect supported models.
