VAIO and Computing: Where to find the model name and serial number?
VAIO product name and serial number location on the product depends on when it was produced.
Note: Each VAIO also carries a black sticker on the bottom with a PCG reference, e.g. PCG-61M2. This reference describes a group of similar models, and is not used for support purposes.
1. Recent models:
Sample model names: SVE14A1S1E, VPCZ23S9E
Sample serial numbers: 28123456-5001234, 27123456-5123456, 54123456-6012345
The product name and the serial number are shown on stickers on the bottom of the notebook.
Exceptions:
SVF142 and SVF152 series: serial number and product name are located underneath the battery.
SVP112 and SVP132 series: Please open the battery door to find the serial number and product name.
SVT112 series: Lift up the adjustable stand to access model name and serial number.
SVF11N, SVF13N, SVF14N, SVF15N series: Set laptop in the viewer mode. The model name and serial number are located in the upper part of the display.
2. Older models
Sample model names: VGN-SR39VN/H, PCG-R600MP
The product name is on a sticker on the display frame or above the keyboard.
The serial number is on a sticker on the bottom of the notebook.
Note: For some models you need to remove the battery to see the serial number sticker.
Alternatively, you can find the information in the BIOS or in Sony Software on your computer.
Method 1:
Click the Start button and then click All Programs.
In the All Programs menu, click the VAIO Care folder.
Click VAIO Care.
The model number is displayed in the bottom of the VAIO Care window.
(e.g., VGN-FW550F)
Method 2:
Click the Start button, then click (My) Computer.
Click Local Disc C:. Next click Windows.
Click the file named Model or Model.txt*.
The file will show the model number. (e.g., VGN-FW550F)
Note: If this file is blank, look for a second file with the same name and open that file.
