Article ID : 00254315 / Last Modified : 19/11/2020Print
If the power is disconnected or the media is removed while recording, will the recording contents be saved?
    We do not recommend disconnecting the power or removing media while recording.
    • If the camcorder is turned off or the memory card is removed while the memory card is being accessed, the integrity of the data on the card cannot be guaranteed.
    • In some cases, you may lose all the data stored in your card.
    • Always make sure the access indicator is green or OFF before turning off the camcorder or removing the memory card.
