What to do if the camcorder does not recognize the wired LAN adaptor?
Disconnect the wired LAN adaptor from the camcorder, then connect it again and check if the camcorder recognizes the wired LAN adaptor.
Alternatively, set Network → Wired LAN in the full menu to Off and then On again and see if this resolves the issue.
