Article ID : 00256174 / Last Modified : 05/01/2021Print
Is it possible to use Wi-Fi AP Mode and the USB tethering / wired LAN adaptor function at the same time?
    Simultaneously using Wi-Fi AP Mode and the USB tethering / wired LAN adaptor
    Yes, it is possible to use both at the same time.
    If you're using
    • the USB tethering function to connect an Android smartphone or,
    • a wired LAN adaptor (sold separately) to establish a connection with a router or other device, and
    • that smartphone is connected via Wi-Fi to the ILME-FX6 operating in Wi-Fi AP Mode,
    the following message may be displayed in either situation:
    • "The IP address of the Wireless LAN Access Point Mode has been changed due to an IP address conflict."
    The communication between the Wi-Fi AP mode connected smartphone and the ILME-FX6 may have been disconnected if you see this message.
    How to re-establish the connection
    If you see a message that you have been disconnected, or the remote control monitoring function doesn't work:
    • Turn the Wi-Fi function off and on again on your smartphone
