macOS Big Sur (macOS 11) compatibility information for application software
We have checked the operation of the application software listed on this page.
IMPORTANT: Operation is not guaranteed for all computers.
Application Software | Version | Applicable Product Categories | macOS Big Sur (macOS 11) | Notes |
Imaging Edge Desktop (Remote/Viewer/Edit) *64-bit only | 3.2.00 | Cyber-shot α (Alpha) | Compatible | |
PlayMemories Home™ | - | Handycam, Cyber-shot, α (Alpha) Action Cam Bloggie / Webbie Digital Recording Binoculars | Not supported | |
Action Cam Movie Creator | - | Action Cam | Not supported | |
IPTC Metadata Preset | 1.2.00 | Check the supported devices | Compatible | Excludes Mac computers with Apple Silicon |
Remote Camera Tool | 2.4.00 | Check the supported devices | Compatible | Excludes Mac computers with Apple Silicon |
PlayMemories Camera Apps | - | Cyber-shot α (Alpha) | Under evaluation | Refer to the Notice / Maintenance information section of the software website |
Imaging Edge Webcam | 1.1.00 | Check the supported devices | Compatible | Excludes Mac computers with Apple Silicon |
HEIF Converter | - | ILCE-1 ILCE-7SM3 ILME-FX3 | Compatible |
The functions of the HEIF Converter are now integrated into Imaging Edge Desktop (Remote/Viewer/Edit), Ver.3.2.00 or later. |
