How do I add additional panes to my Home screen?
Can I add another pane to my Xperia Home screen?
Applicable Android version
- Xperia Home app
- Android 10
- Android 11
To add a pane to your Xperia Home screen
- From the Home screen or Application screen, touch and hold any item that you want to add to the new pane.
- Drag the item to the very right side of the display. An additional pane will automatically appear.
- Continue to drag the item to the right and drop it in the additional pane.
