Article ID : 00262925 / Last Modified : 03/02/2022Print
No sound from the soundbar when playing DTS-HD Master Audio format
    On the HDMI device connected to the Sound Bar, try either of the following settings:
    • Change the audio channel of the disc or content to an audio output other than DTS, for example, LPCM or Dolby.
    • Set the audio output setting of the HDMI device to LPCM.
      (Refer to the device manual if you don't know how to change the audio output settings)
