Article ID : 00257497 / Last Modified : 15/02/2021
Fingerprint unlock does not work after Android 11 upgrade
    We apologize if you experience issues with the fingerprint unlock function. We are aware of this issue and a fix will be released shortly.
    Please perform the following workaround until the software fix is released.
    Restart your device
    To restart your device
    • Press and hold the power key until a menu appears.
    • Tap 'Restart'.
    • See if the issue is temporarily resolved.
    Note: If restarting the device hasn't helped, please move on to the next workaround.
    Perform a force restart
    To force restart your device
    • Press and hold the power key and the volume up key at the same time until your device vibrates and then release the keys. The device restarts.
