Article ID : 00259879 / Last Modified : 26/10/2022Print
What are differences of sound fields?
    Depending on the sound sources, it is recommended to select a desired sound field using the remote control.
    • When watching a movie, select a sound field from the [MOVIE] button.
    • When listening to music, select a sound field from the [MUSIC] button.
    Also, by selecting a sound field from the [2CH/MULTI] button, you can play back without adding surround effects.
    For details about the effects and settings of each sound field, refer to the Help Guide of your device.
    Note
    Depending on the sound source, connection/setting of the speaker, or selected sound field, there may be a speaker that outputs no sound.
