Article ID : 00260005 / Last Modified : 20/01/2026Print
Unable to connect the headset to a BLUETOOTH device with one-touch connection (NFC).
    Check the following:
    • While the headset is set in the charging case, the power is turned off.
      To use one-touch connection, remove the headset from the charging case and make sure that the headset is turned on.
    • Keep the smartphone close to the N-mark on the bottom of the charging case until the smartphone reacts.
      If the smartphone still does not react, move the smartphone slowly up and down and left to right.
    • The NFC function of the smartphone is set to on.
    • If the smartphone is in a case, remove it.
    • NFC reception sensitivity varies depending on your smartphone.
      If you repeatedly fail to connect the headset with a smartphone by one touch, connect it to the headset by on-screen operation on the smartphone.
