Article ID : 00264498 / Last Modified : 22/11/2022Print
Accessibility features on Xperia smartphones (Android 11 and higher)
    Did you know that Xperia smartphones support various accessibility features? They can help you use technology more easily. You can access many accessibility features by going to [Settings] → [Accessibility] on your smartphone.
    • Available features might differ depending on the product and/or Android OS version.
    • Accessibility features are available on Xperia smartphones running Android 11 or later. Some features will be available from Android 12 or later (*1) or Android 13 or later (*2).
    • Some features might require app installation from Google Play, depending on the product and/or Android OS version.
    What accessibility features help with vision and visibility?
    TalkBack
    You can use your device without looking at the screen via voice feedback.
    Select to Speak
    You can tap specific items on your screen to hear them read aloud.
    Font size
    You can make the text on the screen smaller or larger.
    Display size
    You can make the items on your screen smaller or larger.
    Bold text
    You can use bold font to improve visibility (Android 12 or later). (*1)
    Colour correction
    You can adjust how colours are displayed on your device.
    Colour inversion
    You can change your display to a dark background.
    Remove animations
    You can remove animation partly while operating your device.
    Large mouse cursor
    You can make the mouse pointer larger.
    High-contrast text
    You can make the text easier to read on your device.
    Extra dim
    You can dim your screen beyond your phone's minimum brightness, so it's more comfortable to read (Android 12 or later). (*1)
    Dark theme
    Magnification
    You can zoom or magnify to see your device's screen better.
    Audio Description
    Hear a description of what's happening on-screen in supported movies and shows. (*2)
    What accessibility features help with hearing?
    Live Transcribe
    You can participate in conversations around you by showing speech as text on your screen.
    Sound Notifications
    Your phone will always check for sounds you want to be notified about.
    Mono audio
    You can integrate audio channels during playback.
    Audio balance
    You can adjust the left and right audio balance.
    Caption preferences
    You can choose caption preferences for your device.
    What accessibility features help to interact with your smartphone?
    Accessibility Menu
    You can control your device from a large on-screen menu.
    Volume key shortcut
    You can press and hold both volume keys to start an accessibility feature.
    Accessibility Button
    You can start your accessibility apps or switch between accessibility apps (Android 12 or later). (*1)
    Switch Access
    You can interact with your device using one or more switches.
    Touch & hold delay
    You can adjust the amount of time before your tap on the screen becomes a touch & hold.
    Time to take action (Accessibility timeout)
    You can choose how long to show messages that ask you to take action but are visible only temporarily.
    Click after the mouse pointer stops moving
    You can set the mouse cursor to take action automatically when the cursor stops moving for a certain amount of time.
    System navigation
    You can choose between 3-button navigation and Gesture navigation.
    One-hand mode
    The one-handed mode makes it easier to reach distant parts of the screen with your finger (Android 12 or later). (*1)
    Power button ends call
    You can press your device's power button to end a call.
    Auto-rotate screen
    You can rotate the screen automatically when you move your device between portrait and landscape.
    Vibration & haptic strength
    You can turn on vibration for ringing, notifications, and touch.
    Google Assistant
    Keep in touch, manage tasks and to-dos, get answers, control your phone and more. Just say “Hey Google” to get started.
    Smart call handling
    You can handle incoming calls without having to touch the screen.
