The audio system can't connect with my smartphone/Walkman through Bluetooth though it has connected before
If this issue occurs, remove your audio system's Bluetooth pairing information from the connected device, then pair your audio system again. For an iPhone mobile device, Android smartphone, or a Walkman player, follow the provided device procedures:
For iPhone
For details about the iPhone settings, refer to the product manual or support page.
- Turn off the audio system.
- On the iPhone screen, delete the pairing information of the system. For more details, refer to the How to delete the Bluetooth information from a device article.
Note: If the system does not appear on the connected device, skip this step. - Press the POWER button to turn on the system.
Note: If SONY DEMO appears on the display, the system is in demo mode. Press the DISPLAY button repeatedly until the demonstration display disappears, then press the POWER button again to turn the system on. - Press the FUNCTION repeatedly until BLUETOOTH appears on the display.
- Hold down BLUETOOTH/
PAIRING on the system for more than 3 seconds until PAIRING flashes on the display.
- On the iPhone, turn off the BLUETOOTH feature, then turn it on again.
- Tap the system model name which appears in the OTHER DEVICES menu.
Notes:- If a passkey is required, enter 0000.
- The passkey may be called passcode, PIN code, PIN number or password.
- You can confirm that the system has successfully paired with your iPhone when the system model name is listed in the MY DEVICES menu, showing the Connected status.
For Android smartphone or Walkman
For details about the Android smartphone or Walkman settings, refer to the product manual or support page.
- On the smartphone or Walkman screen, delete the pairing information of the system. For more details, refer to the How to delete the Bluetooth information from a device article.
- On the smartphone or Walkman screen, turn off the BLUETOOTH feature and turn it on again.
- Tap the system model name which appears in the Available devices menu.
Notes:- If the system model name does not appear, tap
(more) → Refresh.
- The passkey may be called passcode, PIN code, PIN number, or password.
- Follow any on-screen instructions.
- You can confirm that the audio system has successfully paired with your smartphone or Walkman when the system model name is listed in the Paired devices menu.
