New Android 11 software available for Xperia PRO-I
Note! Software updates are released at different times depending on the operator, market, region, or country. For this reason, we can't share the exact date when the update will be available for your device.
Software build number
Xperia PRO-I: 61.0.A.26.23
- This system software update features the Android security patch level of 1 January 2021.
- For more information, please visit Introducing Xperia with Android 11.
Updating your device
Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
The "Refresh" icon appears in the status bar when a software update is available.
To download and install a system update from the Notification panel
- If you use a device with multiple users, make sure to log in as the owner.
- Drag the status bar downwards to open the Notification panel.
- Scroll down and select the wanted system update, tap the item and then tap UPDATE.
- When the download is finished, open the Notification panel again; if it is closed, then tap RESTART.
Why hasn't my device received an update yet?
Software updates are released at different times depending on the operator, market, region, or country. For this reason, we can't share the exact date when the update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models.
