Article ID : 00400475 / Last Modified : 08/09/2026Print
    Strange noise is heard when wearing the headphones in some locations
    You may hear a popping sound from the headphones if you are in a place that uses devices that generate ultrasonic waves to deter or eliminate rodents and pests. If you are bothered by these noises, use the Sony | Sound Connect app to turn off the Noise Canceling and Ambient Sound Mode functions.
