Article ID : 00293763 / Last Modified : 26/07/2023Print
    Xperia 5 IV software release overview
    Welcome to the Xperia 5 IV software release page.
    • Each Xperia smartphone receives security and software updates throughout its lifecycle
    • Software release timings may vary per country and operator
    Latest software release
    DateSoftware versionSoftware improvement
    2023
    July
     64.1.A.0.941
    • July Security Patch level update
    • Fix for "Ghost App" icon appears on Xperia Home
    • Fix for “Overlapping notifications”
    • Fix for Bluetooth IOT issues
    How to check the software version and how to update your Xperia smartphone
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
    When a software update is available, Refresh Icon appears in the status bar.
    To download and install a system update from the Notification panel
    1. If you use a device with multiple users, ensure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down, select the wanted system update, tap the item, and then tap UPDATE.
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
    Why hasn't my Xperia phone received an update yet?
    • Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models
    Previous releases
    2023
    June
     64.1.A.0.929
    • June Security Patch level update
    • Power consumption improvement while NFC polling
    • GMS package update to April 2023
    • Fixed a Phone call audio problem with BMW media system
    • Fixed an issue where the device could get too hot in certain circumstances
    2023
    March
    64.1.A.0.882
    • March Security patch level update
    2023
    February
     64.1.A.0.869
    • February Security Patch level upgrade
    • Game enhancer improvements
    • Audio improvements
    • Stability improvements
    • Improvement in media volume thanks to market feedback
    • Improvement in Game Enhancer UX thanks to market feedback
    2023
    January
     64.1.A.0.860
    • Bluetooth Low Energy improvements
    2022 64.1.A.0.857
    • Android 13 release
    2022
    October
     64.0.H.11.9
    • Google Mobile Services Package update
    • October Security patch level update
    • Sony Support app version upgrade
    2022
    September
     64.0.A.11.31
    • Game Enhancer User Interface update
    • Improved power consumption for third-party camera streaming (below HD resolution)
    • September Security patch level update
