Article ID : 00302803 / Last Modified : 20/01/2026Print
    When connected to a device, I can heard noise from the INZONE headphones while charging
    Depending on the connected device (computer, PlayStation®5, etc.), charging the INZONE model while the headphone cable is connected to the device may cause this issue.
    • Disconnect the USB Type-C cable from the headphones to stop the charging.
    • Connect the USB Type-C cable to another power source (such as a USB battery charger), or switch to a wireless connection.
