Article ID : 00345261 / Last Modified : 28/05/2026Print
    How to enable the Power-on volume feature on your Google TV™
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    With the Power-on volume feature, you can set the TV volume to your preferred level to prevent the TV from turning on at a loud volume. The TV will always turn on at the volume you set.
    Note: This setting only affects your TV speakers.
    1. On the remote control, press the (Quick Settings) button.
    2. The next steps will depend on your TV menu options:
      • Select SettingsAccessibilityPower-on volumeEnable.
      • Select SettingsSystemAccessibilityPower-on volumeEnable.
    3. Set the volume to your preference.
