Article ID : 00354999 / Last Modified : 02/06/2025Print
    The headphones do not turn on (WF-C510)
    Before you start
    Use dry cloth or cotton swab to clean the charging port. For details on how to clean the headphones, refer to the How to care for the headphones article.
    Note: Do not use an air duster to remove dust or foreign substances. Dust and other debris may enter the sound output holes and cause a malfunction.
    Solution
    Hint: After the issue is resolved, update the headphones' software to the latest version.
    1. Set the headphones in the charging case, and check the status of the indicator on the charging case.
      The indicator repeatedly flashes orange at intervals of about 1 second while charging the headphones or the charging case.
      If you see this, an error occurs while charging. Go to the next troubleshooting step.
      The indicator repeatedly flashes orange at intervals of about half a second while charging the headphones or the charging case.
    2. Reset the headphones.
      Refer to the How to reset or initialize the WF-C510 article or view the How to reset video below:
      If your headphones model does not appear in the Bluetooth device list, disable and reenable Bluetooth in the source device, or leave the Bluetooth setting once and return to try the connection again.
      The issue is resolved.
      The issue is not resolved.
    3. Wear the headphones and check if you can hear a notification or voice guidance corresponding to the operation and status.
      I can hear the notification or voice guidance from the headphones.
       Cleaning the charging ports or charging the headphones may have resolved the issue.
      I cannot hear the notification or voice guidance from the headphones.
    4. Check the Notification & Voice Guide setting:
      1. Open the Sony | Sound Connect app.
      2. In the My Device tab, select Device settings, select System tab, check the Notification & Voice Guide setting.
      The Notification & Voice Guide is set to On.
      The charging may have failed. Refer to The headphones do not charge article.
      The Notification & Voice Guide is set to Off.
      After setting it to On, go back to step 3.
    5. Initialize the headphones.
      Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      Refer to the How to reset or initialize the WF-C510 article or view the How to initialize video below:
    Go to the Headphones Troubleshooting Guide
