Article ID : 00374530 / Last Modified : 20/01/2026Print
    How to connect Xperia to Sony Shooting grip/ Bluetooth® remote commander.
    Information / Solution :
    GP-VPT3 / RMT-VP2 can be used with the following Xperia devices. Please also check the instruction manual of the compatible device.
    • Xperia PRO-I
    • Xperia 1 VII
    • Xperia 1 VI
    • Xperia 1 V
    • Xperia 1 IV
    • Xperia 1 III(Need to upgrade to Android 12)
    • Xperia 5 V
    • Xperia 5 IV
    • Xperia 5 III(Need to upgrade to Android 12)
    This section explains how to connect an Xperia that has a Camera app.
    For instructions on how to connect an Xperia with Photography Pro/Videography Pro app installed, please see here.
    1. On your Xperia device, launch Camera app.
    2. On your Xperia device,select [Photo] mode at the bottom and tap [Gear icon] tap [Menu].
    3. On your Xperia device, tap [Bluetooth remote control], and then tap the switch to enable the function.
    Settings in Photography Pro/Videography Pro app.
    1. On your Xperia device, tap [PAIR NEW CONTROLLER].
    1. On the Bluetooth® remote commander, perform pairing.
      • GP-VPT3 / RMT-VP2: With the ZOOM/FOCUS/LOCK switch set to any position other than LOCK, press and hold the MOVIE button and C1 button at the same time for at least 7 seconds.
    1. On your Xperia device, follow the on-screen instructions.
      • Select [PAIR & CONNECT] and [PAIR] on the notifications and dialogs that appear multiple times when your Xperia device detects the Bluetooth remote commander. The name of the Bluetooth remote commander may be displayed as a Bluetooth address (numerals and letters).
    Note:
    • AF-ON button is not supported.
    • When you perform a factory data reset, pairing information is also erased. To use the Bluetooth remote commander, perform pairing again.
    • If the Bluetooth connection is unstable, remove any obstacles such as people or metal objects from between your Xperia device and the paired Bluetooth remote commander.
    • If the function does not work properly, check the following notes and then try pairing again.
      • Confirm that the Bluetooth remote commander is not connected with other devices.
      • Confirm that you are not operating your Xperia device using other Bluetooth remote commander.
      • Check if the Airplane mode of your Xperia device is set to off.
      • Check if the Bluetooth function of your Xperia device is set to on.
      • Unpair the Bluetooth remote commander.
    Hint:
    • Once you pair with the Bluetooth remote commander, you can operate it with Camera, Photo Pro or Video Pro app, depending on the model.
    • Turn the [Bluetooth remote control] function on or off individually for Camera, Photo Pro and Video Pro app, depending on the model.
    • To change the name of the paired Bluetooth remote commander, find and tap [Settings] → [Device connection], tap (Gear icon) beside the name of the paired Bluetooth remote commander, and then tap (Edit icon).
    Note: Please refer to the link for the trademark information.
