Article ID : 00401039 / Last Modified : 02/06/2026Print
    While two devices are connected simultaneously with LE audio, I can’t connect to the paired device using the Sony | Sound Connect app
    Depending on the connected devices, the headphones may be unable to connect to the paired device using the Sony | Sound Connect app (you can do this by tapping Connected Device(s)Manage Connected Devices screen).
    If this doesn’t work, switch the connection to the other paired device using the device’s Bluetooth settings screen.
