Portable data transmitter
PDT-FP1
Specifications
General
| Dimension |
| Weight |
| OS | Android™ 15 *1 |
| CPU | Snapdragon® 8 Gen 2 Mobile Platform *2 |
| Internal memory (RAM/ROM) | 8 GB/256 GB *3 |
| External memory | Up to 1 TB (microSD/microSDHC/microSDXC) *4 *5 |
| Battery | Lithium-ion battery (5000 mAh) |
| 2D Code Scanner | Yes |
| SIM type | nanoSIM / eSIM *6 |
| Dual SIM specification | DSDS |
| Bluetooth | Bluetooth® 5.3 wireless technology |
| Display | OLED (1080 x 2520), 6.1 inch |
| Speaker | Yes |
| GPS | A-GPS, A-GLONASS, Beidou, Galileo, QZSS *7 |
Network
| Wi-Fi® | IEEE802.11a/b/g/n/ac/ax, 2.4/5/6 GHz *7 |
| Wi-Fi tethering max. number of clients | Up to 10 devices |
| LTE Band | 1, 2, 3, 4, 5, 7, 8, 11, 12, 13, 17, 18, 19, 20, 21, 25, 26, 28, 29, 30, 32, 34, 38, 39, 40, 41, 42, 46, 48, 66, 71 *8 |
| 5G (Sub6) Band | |
| 5G (mmWave) Band | n257, n258, n260, n261 *8 |
| Maximum throughput (5G) | Uplink: Up to 1.1 Gbps/Downlink: Up to 8.1 Gbps *9 *10 |
Input interface
| USB Type-C® terminal (Data transfer) | USB Type-C® (SuperSpeed USB 5 Gbps (USB3.2)) |
| USB Type-C® terminal (CHARGE) | USB Type-C® |
| HDMI® connector | Type-A: [YCbCr 4:4:4 / 4:2:2 / RGB] 3840 x 2160 (60p/50p/30p/25p/24p), 1920 x 1080 (60p/50p/30p/25p/24p), 1280 x 720(60p/50p/30p/25p/24p), 720 x 480 (60p), 720 x 576 (50p), 640 x 480 (60p) *11 |
| LAN terminal | 10BASE-T, 100BASE-TX, 1000BASE-T |
Cooling fan
| Type | DC FAN |
| Thickness of fan | Approx. 5.0 mm (Approx. 0.2 inch) |
| Air flow | Approx. 51 L/min *12 |
Heat sink
| Size | Approx. 37.15 mm x 19.3 mm x 7.3 mm (Approx. 1.5 inch x 0.8 inch x 0.3 inch) |
Power
| Power delivery | Yes (USB Power Delivery) *13 |
| Charging time | Approx. 115 minutes *14 *15 |
| Operating time (FTP transfer via USB in LTE) | Approx. 4 hours *16 *17 |
| Operating time (Video upload via HDMI) | Approx. 2 hours *17 *18 |
| Standby time (LTE) | Approx. 600 hours *17 *19 |
| Standby time (5G SA) | Approx. 450 hours *17 *19 |
Operating temperature
| Operating temperature | 0 - 40 ℃ / 32 - 104 °F |
Accessibility
| Accessibility | Select to Speak, TalkBack, Text-to-speech output, Font size, Display size, Bold text, Dark theme, Magnification, Color correction, Color inversion, Large mouse cursor, Extra dim, Remove animations, Accessibility Menu, Switch Access, Click after mouse pointer stops moving, Auto-rotate screen, Touch and hold delay, Time to take action (Accessibility timeout), Vibration and haptics, Navigation mode, One-handed mode, Audio description, Screen flash notification, Mono audio, Audio balance, Audio Streaming for Hearing Aids (ASHA), Caption preferences, High contrast text, Accessibility button, Allow from lock screen *20 |
Notes
- *1 Android™ is a trademark of Google LLC. With the software update, it is now possible to upgrade to Android 15.
- *2 Qualcomm and Snapdragon are trademarks of Qualcomm Incorporated, registered in the United States and other countries and regions.
- *3 Firmware and preloaded applications take up a portion of internal storage, with the remainder available for user-selected content. Measurement made at time of product announcement and may vary per market. As software updates may change the available internal storage, internal memory may vary depending on market.
- *4 Sold separately.
- *5 microSD, microSD logo and microSDHC logo are trademarks of SD-3C LLC.
- *6 eSIM service availability and condition may vary depending on the countries, regions and carrier.
- *7 This service is not available in all variants or markets.
- *8 Availability may vary depending on countries/regions, carrier, network configuration, software version, and user environment.
- *9 Theoretical value. Performance is subject to environment and conditions.
- *10 Actual throughput depends on network condition.
- *11 Use of a Premium High-Speed HDMI Cable with Ethernet manufactured by Sony is recommended.
- *12 Measured values in Sony measurement environment.
- *13 Use of Sony-designed chargers and cables is recommended.
- *14 When charging with the optional AC adapter (XQZ-UC1) supporting 30 W quick charge.
- *15 Charging time depends on settings and environmental conditions, and actual results may vary.
- *16 When using Transfer & Tagging app for file transfer. Sony measurement.
- *17 Operating time depends on settings and environmental conditions, and actual results may vary.
- *18 When using an external monitor app for video upstreaming. Sony measurement.
- *19 Measured based on GSMA TS.09 operating time measurement method (Ver.12.0). Sony measurement.
- *20 This feature list is provided in Android 15.
