Article ID : 00365767 / Last Modified : 29/08/2025Print
Connecting multiple devices to the INZONE M10S gaming monitor
    The INZONE M10S allows you to connect multiple devices at the same time. With this feature, you can smoothly switch between devices and create a comfortable environment.
    Select the optimal connection port
    The INZONE M10S is equipped with two HDMI ports and one DisplayPort port. To take full advantage of the high refresh rate, connect your devices with the appropriate cables. To maximize your monitor's performance, use an HDMI 2.1- or DisplayPort 2.1-compatible cable to connect to your computer, and an HDMI 2.1 cable to connect to a compatible game console such as the PlayStation®5.
    • A: DisplayPort port
    • B: HDMI port
    • C: HDMI port
