Article ID : 00374432 / Last Modified : 28/11/2025Print
    When the polling rate is set to 8000 Hz while playing the game, my mouse behavior is strange
    The game may (currently) not support 8000 Hz. Here's what you can do:
    • Check the game's specifications, including whether you are using the latest version. Install the newest game update if available.
    • If the game does not support 8000 Hz, change the polling rate using the INZONE Hub software and check if this resolves the issue.
