Microsoft Corporation has announced that it will end its support for the Windows 10 operating system on October 14, 2025, at which point, security updates, fixes, and technical support will no longer be provided by Microsoft.
Accordingly, Sony will no longer be able to assist with any new technical, quality, or security issues with our products if they relate to Windows 10, and we will not be able to provide security updates or implement modifications and validations on our products running on Windows 10. As such, please be aware that these products may not work properly or securely if you continue to use them with Windows 10.
Certain products are compatible with newer versions of the Windows operating system. Please check your product manual for information about Windows operating system compatibility and updates.
Note: Sony cannot support new technical, quality, or security issues with our products caused by use with earlier versions of Windows operating system, such as Windows 95, Windows 98, Windows Me, Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.1 etc., for which Microsoft has already ended support.
