List of specific audio systems that are supported by the A/V sync setting.
    Article ID : 00199141 / Last Modified : 17/06/2026Print
    Which audio systems support the A/V sync setting when connected via an HDMI cable?
    IMPORTANT: This article only applies to specific products and/or operating systems. Please check the Applicable Products and Categories section of this article.
    For the following models, when the A/V sync setting is set to Auto, the TV adjusts the audio and video timing based on the audio system. For other audio systems, even if you set A/V Sync to Auto, the TV will provide a fixed amount of adjustment as if A/V Sync were set to On.
    Currently, the following models are supported:
    • BRAVIA Theatre Bar 7 (HT-A7100)
    • BRAVIA Theatre Bar 5 (HT-B500)
    • BRAVIA Theatre Trio (HT-A8)
    • BRAVIA Theatre Bar 6 (HT-B600)
    • BRAVIA Theatre System 6 (HT-S60)
    • BRAVIA Theatre Bar 9 (HT-A9000)
    • BRAVIA Theatre Bar 8 (HT-A8000)
    • BRAVIA Theatre Quad (HT-A9M2)
    • HT-A9
    • HT-A7000
    • HT-A5000
    • HT-A3000
    • HT-G700
    • HT-S2000
    • HT-X9000F
    • HT-X8500
    • HT-XF9000
    • HT-Z9F
    • HT-ZF9
    • STR-AN1000
    • STR-AZ1000ES
    • STR-AZ3000ES
    • STR-AZ5000ES
    • STR-AZ7000ES
    • TA-AN1000
    Notes:
    • To set A/V sync to Auto:
      1. Open the Settings screen.
      2. The next steps will depend on your TV menu options:
        • Select Display & SoundAudio outputAudio system settingsA/V sync → Auto.
        • Select Display & SoundAudio outAudio system settingsA/V sync → Auto.
        • Select Display & SoundAudio outputA/V sync → Auto.
        • Select SoundA/V sync → Auto.
    • The AV Sync feature can be used when outputting the TV's audio signal from a soundbar/home theater system via an ARC/eARC connection.
